Wireless home internet
I have everything I need to operate remote with the exception of a decent internet connection. I can connect and, after intermittent times, will disconnect just listening, transmitting is worse as it disconnects immediately. I have a 6 mbps and below, mostly below, download and less than 1 mbps upload. My question is this. Has anyone tried or are using a wireless home internet with 5g. I discovered that I am in an area that, with a popular provider, provides Home internet 5g. Has anyone had any experience with a wireless home internet. If it does what it says it does my speeds would increase a lot and perhaps would better my remote experience. Thanks, Tim KE4UK
Your 1mb/sec upload is part of the problem and if you are running your panadapter/waterfall at 100% you will max out your upload bandwidth resulting in what you are seeing.
Slice these 2 sliders all the way to the left and see if your experience improves. If you have them all the way to the right, your upload bandwidth will be in the 1.6mb/sec area and that is more than you want.
We have used 4G mobile internet a few times to connect a laptop to the Flex at the clubstation, which worked good. Some guys in Switzerland use 4G too at their remote site.
Just be sure you have a unlimited or at least high volume plan.
- 637 The Flea Market
- 144 SmartSDR+
- 433 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
