Mic settings via Acc input 6400
I am trying to use the acc for use as a mic input. The signal chain is: dynamic mic to mic pre. Pre to acc 15 pin port via a trs to bnc cable, bnc to 15 pin connector.
On the radio I set the mic button to acc, and select the +acc button to on (blue)
When keying via foot switch, and setting gain via outboard pre, I do not seem to get modulation on the scope. Mic gain and proc do not seem to work. I assume I am adjusting gain and compression outboard. I do hear audio via monitor.
some guidance in mic set up via acc would be appreciated.
cheers all
Brad
Hi Brad
I opened a support ticket for you.
As I understand the use of the "ACC" mic via the 15pin connector:
- If the +ACC button is enabled, the ACC audio source will be added to the selected BAL audio or MIC audio (i.e. for a voice keyer plus your regular selected microphone source)
- if you Select ACC as the microphone source, that will be the single audio input.
Alan. WA9WUD
I think I found the answers I am looking for in the hardware reference manual.
https://www.flexradio.com/documentation/flex-6400-and-flex-6600-hardware-reference-manual-pdf/
Any news on this? What is the pin out for line in? I see pin 1 is line in, but what is ground and do you use tip and sleeve?
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
