Problem with adding virtual ports
Slawomir
Slawomir Member ✭✭
Hi everyone,
I'm having trouble adding a viery CAT port in SmartSDR CAT. The program selects only a free port and after adding it I have the following message: "Virtual serial port failed to create. Double weseck the Serial Port settings. There are free ports in Windows, but SmartSDR Cat allocates the port without the possibility of changing. Do you need to add WIN post in the device manager first to be visible in Smart SDR CAT? How to solve this problem?
73's
Slawomir
    No, it should 'just work'.
    There is something with in Windows permissions causing this not to work.
    I'll open a support ticket for you.
  • gi4fue
    gi4fue Member ✭✭
    @Mike-VA3MW I have this issue too, running W11 here
    73, Charlie
    I think your problem is different based on your post.
  • gi4fue
    gi4fue Member ✭✭
    Slawomir... I followed this and it worked for me
    https://community.flexradio.com/discussion/comment/19718961#Comment_19718961
