SmartLink Edit/Update?
SmartLink was working and now it does not.
I changed networks that connect the Flex6600.
How do I update the linkage?
This will get you started:
I did not see the answer.
Hi Robert
Do you not see the video? Click on the picture.
It will walk you through some things to review for your Smartlink
I know about SmartLink and have installed it OK.
I recently changed networks and do not see how to edit SmartLink to access the new network.
It is not a set-up or use question.
Hi Robert
If you changed networks, you may need to follow the steps again to register your radio with your router especially if you have a new router / modem.
If that is the case you need to review the setup or if you are having troubles, please open a support ticket.
helpdesk.flexradio.com
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 153 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 867 Genius Products
- 445 Power Genius XL Amplifier
- 308 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 717 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 939 Third-Party Software
