SmartLink Edit/Update?
SmartLink was working and now it does not.
I changed networks that connect the Flex6600.
How do I update the linkage?
This will get you started:
I did not see the answer.
Hi Robert
Do you not see the video? Click on the picture.
It will walk you through some things to review for your Smartlink
I know about SmartLink and have installed it OK.
I recently changed networks and do not see how to edit SmartLink to access the new network.
It is not a set-up or use question.
Hi Robert
If you changed networks, you may need to follow the steps again to register your radio with your router especially if you have a new router / modem.
If that is the case you need to review the setup or if you are having troubles, please open a support ticket.
helpdesk.flexradio.com
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
