SmartLink Edit/Update?
SmartLink was working and now it does not.
I changed networks that connect the Flex6600.
How do I update the linkage?
    This will get you started:
  • Robert Gross
    Robert Gross Member ✭✭
    I did not see the answer.
  • Robert Gross
    edited March 2022
    Hi Robert
    Do you not see the video? Click on the picture.
    It will walk you through some things to review for your Smartlink
  • Robert Gross
    I know about SmartLink and have installed it OK.
    I recently changed networks and do not see how to edit SmartLink to access the new network.
    It is not a set-up or use question.
  • Robert Gross
    Hi Robert
    If you changed networks, you may need to follow the steps again to register your radio with your router especially if you have a new router / modem.
    If that is the case you need to review the setup or if you are having troubles, please open a support ticket.
    helpdesk.flexradio.com
