Windows 11 Display Settings with 6400M and Two Monitors
Good Afternoon Flexradio community.
I have one 32" monitor connected to my computer and also one 32" connected to the back of 6400M in the Ext. Display port. Here is the issue at hand. I have 2 HDR compatible monitors and yet when I have the windows settings as Duplicate, HDR is not compatible. Yet, on Extend and Show on 1 display HDR is active. I guess the question ultimately comes down to what is the correct setting for the monitors where I can have loggers and other programs on Screen 1 and my 6400 on Screen 2 when I have the radio turned on. Other than that, when I just have the computer on and no radio on, I would like to have both screens the same if possible.
What are your thoughts on this?
Mark Griffin, KB3Z
A monitor plugged into the radio’s hdmi connector is always going to mirror the radio’s front screen, regardless of your computer activity or inactivity.
Ok, I understand that when the radio is on. But what if the radio is not on? Then I would like to know what the best Windows 11 setting would be. Extend the displays, or just one display or duplicate the displays. That's what I would really want to know when and if the radio is off.
Mark Griffin, KB3Z
Well, assuming your computer can run two monitors, you would unplug the monitor from the hdmi socket on the radio and plug it into the second hdmi socket on the computer (or the adapter that allows a second hdmi connection).
So basically in a nutshell, not having the HDR capability is not a real big thing!
Mark Griffin, KB3Z
SmartSDR doesn’t support or require HDR.
Hi Mark,
My suggestion for contesting is both monitors connected to PC. Run SmartSDR on PC. You can turn off the right side panels wen not in use by clicking the second icon from left in bottom left of SmartSDR (looks like a tower). This will help screen real estate. Also running spots on SmartSDR vs front of radio is easier to see them. Run the front of the radio in Smart Control mode so you can still use the buttons and knobs on radio.
if you have multiple panadapters you can pop them out into their own window by clicking on the arrow in upper right of panadapter window and then move each panadapter to wherever you want and minimize the main SmartSDR.
Play around setting up that way along with whatever logging program you use and you can arrange windows to have an effective work flow for contesting. That way both monitors are available for use by the PC when radio is off or if you just want to run radio from front screen.
Smart Control is one of the best features that get underutilized with the M series radios or Maestro.
Give me a call and I can demo these features.
Mike W, might be worth a video about optimizing Your desktop for a contest. Each person will have different preferences but showing the pop out feature and Smart Control would be a good tutorial for new users.
Dave
This is a good idea, but I think I will deflect watching the Contest University videos since they touch on all of that.
Additionally, running SmartSDR on the pc offers several additional tools not available on the M or Maestro. FRstack is a personal favorite with memories that are more complete than the profiles, hotkeys within frstack, a stream deck with customizable buttons, or the latest tool, node red.
You can run FRStack, Node Red, and Stream Deck all while using the front panel of the M series. SmartSDR is not necessary for those tools.
I do like using SmartSDR and Smart Control for some contests but use the front panel for FT4/FT8, giving more screen real estate for WSJT-X, JTAlert and logging program.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
