Tutorial for Smart SDR on Ios
I have purchased smart sdr for ipad and I was talking on 2meter and I am so hot it is not even funny. Audio sounds like trash. I have turned mic gain all the way down to 1 and still I am blasting in beyond belief. I am at a loss here. Ev en on HF I am crazy overdriving. Any ideas?
Flex 6400
brand new ipad pro 12.9
Smart sdr local connection
Go into Flex Settings…Phone… is mic boost on??? If so turn it off an retry…
73 Ronald
On the ios smart sdr? I am not seeing it
Start the program…at the bottom you should see several tabs…Panadapter…Flex Radio Settings… Tools
Select Flex Radio settings… then Phone
Ronald
Ahhh yes I see it now, did not see that there are 2 settings tabs. Guess I should open my eyes more. One more question. Is there a way to make it not disconnect every time I click off screen or change settings like tx settings? It clicks off screen and disconnects every time. I will also have to learn battery settings for power savings as this is gobbling my battery on ipad.
Yes
I don't have it in front of me, but take a scan of the iOS manual and you'll find it.
Not sure what you are running into on the disconnects....mine is working as it should. Yea I know that does not help you...I'm just not sure what you are referring to. Concerning the battery life...checking you screen brightness and other IPad settings. You can also bring up the Panadapter and go into the left side menu...go down to Display...you can change the Average and Rate which may help.
Also under settings you will find "Show Demo Device"...if you have not looked at this it may answer some of your questions. Also at the bottom of that screen you will find the link for the "Manual". Very easy to understand and will provide some context to some of your questions. I hope this helps...
Ronald
when you first bring up SmartSDR IOS at the bottom right click on settings, slide "Ask before disconnect" to ON and "Disconnect on close" slider off.
Hope it helps
FWIW, seems most iOS users overdrive the audio at first, me included. It seems pretty weird to have to adjust two mic level controls to get acceptable audio.
Funny thing about Audio.
All my Yaesus had the audio drive set to 50, yet when set correctly with the hand Mic that comes with the radio, somewhere below 10 is the correct setting.
Same on the IC-7300 I use for some testing. The default Mic audio was way way too high. Again, I think it was 50 and 9 was the correct number for me.
The moral of the story is, regardless of the Mic audio setting number, as the Ham in control of your transmitter you have to use the Metering the radio has to ensure you Mic gain is set accurately.
For FlexRadios, it is the LEVEL meter with peaks no more than -5db
For OEM radios, it is the Mic ALC meter (they all have them). It should be just 'kicking' with the processors off.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
