CW Skimmer Spots to N1Mm
Good Evening,
I have CW Skimmer working between SDR Bridge and N1MM. Slice A is on 40 meters and I went into the telnet and set N1MM to Skimmer 1 Localhost:7310. Currently what CW Skimmer is picking up is being sent over to N1MM and the bandmap. I can also have CW Skimmer active on 80 meters through SDR Bridge. But my question is, can I send the spots that CW Skimmer is picking up on Slice B over to N1MM also? I don't think that N1MM allows for 2 telnets to be working at the same time. Am I correct in that assumption?
Mark Griffin, KB3Z
Mark,
Have you tried using SliceMaster instead of SDR Bridge? It can handle multiple slices and they are all sent to the 1 telnet server in SliceMaster.
I was advised to try Slicemaster. But can it send multiple Spots from CW Skimmer, Slice A and Slice B to N1MM? And if so are there directions on how to do this?
Thanks!
Mark Griffin, KB3Z
I finally got both spots from Slice A and Slice B to go to N1MM. In CW Skimmer for slice A the telnet is 7301. Slice B is 7302. In a flexradio program called Slicemaster I have enabled aggregation server at telnet 7310. I went into N1MM and created a cluster of Skimmer 1 with a telnet of Localhost:7310. Spots are now showing up in the Telnet window of N1MM. I changed the contest to CWOPS and the spots are making it to the bandmap. FINALLY!
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
