CW Skimmer Spots to N1Mm
Good Evening,
I have CW Skimmer working between SDR Bridge and N1MM. Slice A is on 40 meters and I went into the telnet and set N1MM to Skimmer 1 Localhost:7310. Currently what CW Skimmer is picking up is being sent over to N1MM and the bandmap. I can also have CW Skimmer active on 80 meters through SDR Bridge. But my question is, can I send the spots that CW Skimmer is picking up on Slice B over to N1MM also? I don't think that N1MM allows for 2 telnets to be working at the same time. Am I correct in that assumption?
Mark Griffin, KB3Z
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsMark,
Have you tried using SliceMaster instead of SDR Bridge? It can handle multiple slices and they are all sent to the 1 telnet server in SliceMaster.
I was advised to try Slicemaster. But can it send multiple Spots from CW Skimmer, Slice A and Slice B to N1MM? And if so are there directions on how to do this?
Thanks!
Mark Griffin, KB3Z
I finally got both spots from Slice A and Slice B to go to N1MM. In CW Skimmer for slice A the telnet is 7301. Slice B is 7302. In a flexradio program called Slicemaster I have enabled aggregation server at telnet 7310. I went into N1MM and created a cluster of Skimmer 1 with a telnet of Localhost:7310. Spots are now showing up in the Telnet window of N1MM. I changed the contest to CWOPS and the spots are making it to the bandmap. FINALLY!
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
