Problems with PTT via SmartSDR CAT (foot switch)
Hello!
My setup: Flexradio 6500, SmartSDR 3.2.39, Windows 10 21H2
I connected a foot switch for PTT to a serial port via SmartSDR CAT.
Sometimes the radio doesn't go on the air. There is no transmission power out.
But I can see the audio control and TX flag. See picture below.
If I then release PTT and press again, it usually works but not always.
Pressing MOX with mouse within SmartSDR does alway work.
Any idea?
Best Answers
  • Hardy
    Hardy Member ✭✭
    Answer ✓
    Update: This must be a timing bug within SmartSDR CAT.
    As soon as I enable "logging" the failure disapears. Disable logging reenables the failure.
  • Hardy
    Hardy Member ✭✭
    Answer ✓
    I got the answer from the help desk which solved the issue:
    >The CAT COM Port PTT was not originally designed for use with an external footswitch, though many have done this.
    >The most common cause of the issue you report is "keybounce" on the footswitch causing inconsistent operation.
    I put a 470 nF capacitor between the contact of the foot switch and got success.
