Correct version of SmartSDR ??
I have a maestro and I went to use it and it hadn’t had the software updated in about six months. So I went through the update process on the Maestra which updated the The Flex 6400.
It updated the Maestro and the 6400 to version 2.7x.
For FT8 Are use my computer as the interface to use the Slice Master.
When I booted my computer up SDR asked me to update and basically forced me to downgrade to I guess 2.61 which I used previously. It completely reset the configuration and I don’t understand why installing software update on the Maestro and radio didn’t prompt the SDR on the computer to update to the same version. Anybody have any ideas?
I didn’t see version 2.61 listed on the Maesto version select list. I believe it was 2.74, because 3.x is the $199 upgrade version.
Now Slice Master and the radio have to be completely reconfigured. 🙁🙁
I hope Flex soon supports FT8 on the Maestro!
Thanks!
Download 2.7.6 for Windows from Flex. You are running an older version on the PC and therefore it downgraded the radio.
Also, once you have both the Maetro and PC at 2.7.6 you can use the Maestro to control the radio but you need to run both SmartSDR CAT and DmartSDR DAX on the PC. In both CAT and DAX at the top is a pulldown. Select Maestro for the client and you are good to go.
Thanks everyone!
It’s strange. The pc software asked me to downgrade instead of upgrade to 2.76… Oh well??
Thanks again!
Installed and worked like a charm.
Thanks!
If the software asked you to downgrade, you likely picked the wrong SmartSDR Icon from your desktop. Have a close look at your Icons and you will see version numbers.
To upgrade the pc version to match the radio requires going to the flex website, selecting the desired version, downloading it, and running the installer. Won’t happen automatically.
So, if the pc version matches the radio, all will be good. If the pc version is higher than the radio, the radio will be upgraded. If the pc version is lower than the radio, the radio will be downgraded to match the pc version.
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
