Serial over IP Tools (serialtcp)
Mike-VA3MW
I wanted to thank Gerry, W1VE who made this great tool available for serial tunneling (serial via long remote :) ). I love what he did with it and even the log screen is so helpful.
This is his post on the N1MM group:
I've just released my version of a very useful tool. It's called SerialTCP.  It's an application that will transform Serial-to-TCP and TCP-to-Serial. It runs in both Client and Server modes, so
that you can use it one way at your station and another way from your remote site.  You can take ANY flavor of CAT and run it over the Internet or your LAN. In addition, you can just use your server piece and use N1MM+ with IP for CAT.
The application is free, and is licensed under the GNU General Public License.   You can download it at https://files.w1ve.com/serialtcp.zip.   In the Zip files are self-contained exe files, meaning they require NO additional other files, no Installer is required, and can be run from any location in the file system.  On the menu, there is an ability to launch another copy:  you can launch as many copies as you like.
In the Help->About is info about how to get the source code.  There are binaries for Windows-x86, Windows-x64 and Windows-ARM.   This is Microsoft's latest tech, so it will run on Windows 10 and later.
Feel free to give me feedback directly to gerry@w1ve.com.
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    The link to the ZIP file has a trailing "." (dot) in it - you will need to copy the link and edit out the dot in order to use the link.
  • Val  DM1TX
    Val DM1TX Member ✭✭
    Great tool! Thank you Gerry!
