I am new to the FlexRadio community, looking for what logging software is suggested.
Best Answers
For everyday operating, I highly recommend DXLab. It is complete suite of programs, is free and the customer support is the best anywhere. The author is always available to answer questions on the reflector. It is complex and does have a learning curve, but you will never outgrow it.
For contesting, N1MM+ is the most popular, however for many years I have used WriteLog. Great contest logger, costs $30 per year.
My 2 cents...
73, Craig KØCF
3 -
Hi Scott, It is a really personal decision. I like ACLog by N3FJP, but there are many many choices - including one that will fill your needs. I suggest finding several that you can try for no cost, then make your decision based on what works best for you.
I don't do any serious contesting, but I do enjoy jumping in now and again. ACLog has separate logs available to accommodate most contests, making it much easier to enter the data. When I finish the contest, I can submit my log, then import those contacts into my main log so that I have everything in one spot. It is the best of both worlds, separate logs for each contest and all contacts in one spot for QSL purposes.
Another nice thing about ACLog is that it interfaces to Flex 6000 series radios using the Flex API - very plug and play.
[{"insert":"Craig:\nthanks for getting back to me. I am not a contester but just starting to do more HF with the Flex Radio (which is a great piece of equipment) . I have gotten my LoTW set up but pretty much got brick walled at this point. I want to get the maximum use of the Flex Radio with logging software. \n73,\nKC9TTF\nScott \n"}]0
I got active in amateur radio last year after much time away. I have found Log4OM to be very good for my purposes. I have been mostly on FT8 and Log4OM connects to the various communication ports to allow 'automatic' logging of contacts (in quotes because clicking to verify is required by WSTJ-X). Log4OM connects and uploads to LOTW and QRZ.com automatically and includes spots (which can be displayed on the Flex screen using FR stack. And it's free (though you can donate if you value it).
I too use AC Log for daily logging and N1MM+ for contests.
Thanks, everyone for your time and help with logger software.0
Just a follow up to my logging software questions. Thanks for all of the suggestions, ideas and opinions. It was very helpful with making a well informed decision. I tried TQSL and got it to work but decided it was too much typing. I decided on N3FJP and I have had good results thus far.
I'm still wanting to get the most out of my Flex6400 and software tools.
73's
KC9TTF
Scott (Middleton, WI)
Not logging, but very useful is the free download FRstack. I don’t operate without it.
I use DXLabs, DX keeper program it works we'll as most other Logging software does with the Flex Radio's SmartSDR, I haven't had any problems thus far over many years of operation.
The FLEX Logger Program works okay and is simple to set up but hasn't been updated in quite a while.
A lot of people use N1MM and Log4OM for more contesting type operation.
Be careful with 3rd party programs that send control commands to the Radio as they can cause you a lot of frustration getting to know the radio and trouble shooting problems that aren't even the Radio's SmartSDR Fault.
this is just my 2cents
Very good Advice, I don't contest, yet, but might in the future. I just want to get the most out of my 6400. Right not I just don't know what that is.
KC9TTF
Scott
Contesting can be intimidating. Most contests are too intense for me, so I usually jump in from time to time and make a few contacts. When it gets tiring or I just want to relax, I move to a non-contest band or mode and resume casual operation.
The various state QSO parties are a good way to get contesting experience without so much intensity. I also like the North America QSO Party (NAQP). Field Day and Winter Field Day are also great for getting into contesting. There are lots of participants who, like me, are not "contesters" most of the time. It means that the pace is usually a little more relaxed and you can find CW speeds below 30 WPM.
The Field Day events are a great time to hook up with a club station so that you can get your feet wet and get some good guidance from seasoned contesters.
Here is a link to the WA7BNM contest calendar. I use this to decide which, if any, contests I will participate in. I usually peruse it on Thursdays to see if there is something I would like to try. Then I download the appropriate contest log from N3FJP (I bought the full use license to give me all available logs). As long as I am having fun, I keep going.
So give it a shot, but don't burn yourself out when starting off.
Len:
Thanks again for the help. I won N3FJP at a ham swapfest a couple of years ago. I just recently opened it and have got it activated and running with LoTW. I am not planning to become a contester but I have started doing some of the POTA stations. Especially on weekdays when the traffic is lite.
My learning curve is going ok with the FlexRadio but I get reports that I am over modulating but my carrier is strong. I also am just starting to learn and use profiles.
Scott
Hi Scott,
That is usually caused by overdriving. Set the Mic gain so that voice peaks do not go higher than about -5 dB. If that is not the issue, then you might be getting RF into your audio. I had that issue on 40 meters and had to put a ferrite on my key line. Note that any line into the radio can conduct RF in, so don't just look at the mic line.
Len:
I'll be doing some RF hunting this week.
thanks,
Scott,KC9TTF
N3LJP is my favorite after trying several others.
I use it live at the POTA activation so I don't have to log my contacts later. When I finish an activation it only takes about 5 minutes, if that, to create ADI files, send them to the coordinator and upload them to QRZ.
Van N4VGE
Thanks for your information.
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
