On Air LED Sign
David,
Use TX1, TX2, or TX3. I would use TX2 since I am using TX1 to key my amp.
No, you would not need another relay.
If you are not using full QSK & set the CW Delay to a value long enough that the rig does not drop out of transmit between characters, you would not have it flashing when you send CW.
73, Ray, K9DUR1 -
I think you should keep it connected during CW to check if either you, your wife, dogs, or cats are prone to Epilepsy.
But on the serious side Ray has good advice! Now I have to go and get me one of those!0 -
My daughter gave me one of these signs for fathers day! It hangs outside my shack and is wired to a WIMO switch which I can control via a phone app. When I'm operating either at home or remote I just turn on the sign via the app and my daughter and wife know I'm on the air from wherever I may be..
Cal / N3CAL
3 -
That's pretty cool David!
Cal/N3CAL
Ray, I am dumb as a board. Help. So I connected my nifty self-important LED "On Air" sign to TX2 -- zip line to my 12VDC power source, sign-to-power interrupted with an RCA plug to TX2. I am assuming TX2, on transmit, closes the loop and supplies 12VDC to the LED sign. When not transmitting, the power should be off. Appears TX2 is closed and the sign is on continually.
What did I do wrong?0 -
David, The TX1-3 jacks do not supply power - they short to ground. Connect your 12VDC power supply to the plus terminal of your sign. Connect the - terminal of the sign to the center pin of the TX jack you are using. Now it should work.0
Works like a charm. Thanks, Ray.0
Okay, I am going to delve into the vanity of an ON THE AIR sign.
Two questions: I have a Flex 6300. Since I only have one TX port, would it be okay to use that to key the sign and also key the amp?
Also, I am primarily a CW op. I would rather not have the sign key on and off as I send code. Can someone guide me toward a simple circuit that would I delay the on/off of the LEDs for about 500 milliseconds?
Steve, W6SDM
You could use an 8 Port USB Relay that plugs into the back of the radio and every time you go into TX, the relay closes.
Mike, now you have me thinking. I have an 8-port relay board that I got years ago for another project and never used. I would use one relay to key my amp, another for the on-the-air sign, and then I need to come up with some creative uses for the other six ports. I am sure the people on here have some ideas. 🤣
Steve, W6SDM
Have it turn a spotlight on your tower every time you transmit! Wouldn't the neighbors love that?
For others, this is the document on how you can play with this.
https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
