WKFlex - CW remote with SmartSDR and Winkeyer
Hi Val, I can search online and see what WK strings are emulated by the microHAM, it could be an initialization problem. Unfortunately I do not have a microHAM to test with. In meantime, as suggested for the WKSerial, slow down the init sequence by increasing the Command Delay time.
Please let me know
I would like to make WKFlex more compatible and working with different Winkeyer versions and clones. Because I do not have access to all the hardware, I'm asking if anyone using one of those units is willing to run some simple tests for me.
Please reach out to me directly.
73, Max
Is there any way to speed up the ptt over Lan on my own local network? I can get the first character of my call out at 25 wpm before I see the Flex 6500 respond with TXing. same with the last character with radio still TXing nearly a sec after I have sent the character. This is with the radio about 100ft away in the shed and LAN cable run directly out to shed from the Router here in the shack.
Using Winkeyer USB and V1.1 of WKFlex.
Thanks for any tips
Lar k1UO
Larry
If there is a delay, I doubt it is in the LAN. Unless you have a pile of collisions going on, the odds are about zero. You may want to look elsewhere.
There is a delay generated by the whole chain which can't be really reduced much:
1) Winkeyer needs to wait until your paddle sends the whole character to transform it in an ASCII symbol;
2) Winflex gets the symbol through the (virtual) serial port, processes it, and sends it to SmartSDR through the SmartCAT virtual serial port;
3) The virtual SmartSDR Winkeyer processes the symbol transforming it in dot and dashes and starts the sending process
On top of that there is your (selectable) speed offset which adds some wanted delay.
Sorry, this is the price you have to pay to transmit an acceptable CW with the paddle over a remote connection.
Hope this helps
73, Max
Thanks Max... Actually the Remote Rig solution I used to have was the best cw solution over a remote WAN connection..just more expensive. I thought the Winkeyer might be as good here on a local LAN but from what I see here the Maestro is a bit better, response wise, but I am having character dropouts and occasional character clipping. May need to go back to the Remote Rigs.
Anyone looking to save a little on a new Winkeyer USB..let me know!
Hi Larry, I built a keyer into my TeensyMaestro, and I *think* it uses the same method for remotely keying my Flex 6400 as the Maestro uses.
Depending on network quality, I need to increase the CW delay (not TX delay) when operating remotely. Generally, I can set it to 100 ms and get perfect CW. If the network quality is especially good, I can drop it to around 30 ms. If it is really bad, I have to add a bit more. I use FDX to listen to my keying while I adjust CW Delay.
Try adding some CW Delay, and see if that cleans up your remote keying with your Maestro.
Update on the compatibility, WKFlex works with MicroHam.
WKFlex V1.2 has been released today.
It is a maintenance release to support the newborn in the K1EL Winkeyer family, the WKUSB-AF.
After I just hit one of the paddles of my Bencher WKFlex crashes. No matter version of WKFlex. It does start as it should. My computer runs W10 Pro x64
Looks like you had everything running before. What changed? Please send a screenshot of your Winkeyer configuration using the standard K1EL tool, WKTool5.3. I suspect something in your configuration is not handled correctly. Please write direct to me (max.i8nhj@gmail.com).
I'll post my finding here anyway.
73, Max
Hi Danny,
After problems with the RemoteKeyer I have now tested WKFlex-v1.2 with excellent performance.
I am using SSDR 2.7.6 with an Flex6600 and a old WinkeyerUSB. An instant SideTone
is generated with a separate sinus generator keyed by theWKUSB and sent to a separate
speaker.
I am mostly working on the Microwave bands. Using several different antenna relays
with different switch over timings. To avoid hot switching I normally use manual PTT.
When testing WKFlex-v1.2 I found that Breakin was activated all the time even if
Breakin was unchecked in SSDR P/CW setting. Sometimes also the PTT was stuck in
TX state. I then needed to send a character to release the TX state.
I wish to have check box to inactivate Breakin.
Jens SM6AFV
Hi Jens, I think you are talking to me addressing me as Denny, which is fine anyway.
I'm happy you like WKFlex, we will keep adding functionalities and fixes. A new version will be out soon.
Look at the new WKUSB-AF for a better audio integration.
As about the BKIN function, this is a SmartSDR function, not controlled by WKFlex at all. Try sending with the CWX panel and you'll see the same behavior. My guess is the BKIN function is relevant to local keying, not to any other CW transmitting function.
I have seen the PTT issue and my feeling is that it is a SmartSDR issue, but I'll investigate it more deeply.
73, Max
Hi Max,
Thanks for the info and
sorry for the name mixed up.
Jens - SM6AFV
HI again Max,
I have now upgraded SmartSDR to version 2.8.0
When testing WKFlex-1.2 I still have the problems with Breakin activated and
after sending cw the radio does not release PTT.
Jens - SM6AFV
Hi Jens, as discussed before, the break-in activation is a SmartSDR feature, it only works for keying the radio locally with a keyer plugged-in into the key jack. There is no way I'm aware off to disable it using the SmartSDR winkeyer emulation or CWX. About the PTT, please reduce the Delay to a very small number, say 300, and check if this changes something.
73, Max
WKFlex 2.0 is ready for download.
I'm happy to announce the new release of WKFlex. This is a major release with functional improvements, cosmetic fixes, and new features including the full interface to N1MM (and other logging applications). Virtually any Winkeyer model (and clones) is now supported.
Download the ReadMe file from here: https://www.dropbox.com/s/hmts3z3s30sohsk/WKFlex%20Readme.pdf?dl=0
Download WKFlex 2.0 from here:
73, Max
WKFlex worked great on the first try. I'm using a paddle to a WinKeyer USB and a Flex 6400 remotely. Beautiful solution. Solves the problem of using a paddle with a remote, not wanting to use the pc keyboard to send. Thank you very much. 73 es DX, Mark, W0QL1
WKFlex 2.1 is out!
This maintenance release fixes the known issue inherited from Ver 2.0 about the paddle missing some letters after sending several N1MM messages.
As an extra feature, N1MM buffered speed change (to send, say 5NN faster) is now reflected into the radio and local winkeyer.
Download the ReadMe file here: https://www.dropbox.com/s/hmts3z3s30sohsk/WKFlex%20Readme.pdf?dl=0
Download WKFlex V2.1 here: https://www.dropbox.com/s/e4skwz1pl63ff55/WKFlex-V21.zip?dl=0
PS: I'm running out of ideas and I'm not sure if WKFlex can grow more. Please feel free to suggest new features and enhancements!
Enjoy CW
73 de Max, N5NHJ and David, N1BIT
some possible WKFlex for iPad in the future? Could be great for field ops. TKS de IU3BRO Tilio0
Ciao Tilio,
I do not have experience with programming Apple devices, but I'll investigate.
Thanks for the idea.
73, Max
Tilio,
I did a quick research. Looks like there is not an easy, economical, and practical way to connect a Winkeyer to an iPad. The Winkeyer USB is not recognized by the iPad and the USB to Serial MFI (Made For IOs) converters (assuming the use of a serial Winkeyer) are not easy to be found. So, no go in the foreseeable time.
73, Max
[{"insert":"Hello Max and Tilio,\ncalls are ct1drb and ok8rb, name is David Quental and qth close to Lisbon.\ninstead to connect, via USB, a Winkeyer to an iPad, is there a change to access to an online Winkeyer?\nOr to an application that manages the Winkeyer.\nJust an idea.\nBest 73 all.\n\nCT1DRB/OK8RB\nDavid Quental\n\n"}]0
Hi David,
There are several ways to connect a Winkeyer over a network. Using a USB device server is one option, using WKRemote by K1EL is another option. It depends on what you are trying to achieve.
But this is a bit off-topic.
Hi all, I'm using wkflex 2.1 but got two issues: not able to have app displayed, to be able to stop and setting and continuing, second actual configuration doubles all my hits, i.e. when I key "K" I get "KK". any suggestion? Thanks0
Forgot to say: using Win 8.1: maybe this is the problem?0
Hi Tilio, send me an e-mail to my address, so we can keep going with debugging this issue (in Italian) and I'll report the findings here.
Tilio's issue has been investigated and somehow addressed.
Tilio is using the K3NG Arduino keyer emulating the Winkeyer. If the FEATURE_COMMAND_LINE_INTERFACE functionality (in keyer_features_and_options.h) is enabled along with the Winkeyer emulation, the characters sent by the paddle are echoed twice and, therefore, transmitted twice by the Flex through the WKFlex.
The workaround is to disable the CLI functionality in the Arduino code.
I'll reach out to Anthony, K3NG to check for any possible fixes; In meantime, feel free to touch base with me for any possible WKFlex/K3NG interaction issues.
Thanks, Max, in detail the trick has been to disable the FEATURE_COMMAND_LINE_INTERFACE (doing // FEATURE_COMMAND_LINE_INTERFACE) in the sketch "keyer_features_and_options.h", and magically double beat disappeared when using WKFlex. Thanks again Max, you and this forum precious0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
