RTTY Roundup
Just wondering how many used Flex equipment in the recent RU.
I used my 6600, PGXL, TGXL and AGXL for 24 hours total. Running SO2R at about 900-1000 watts per band. Everything worked flawlessly. So good, that after the first 12 hours I was hesitant to shut things down before taking a 6 hour break. So I put the amp in standby, left everything else on, and went to bed! Picked back up in the morning and went for another 12 hours. This is the first RU in which I was able to use all the XL pieces together.
73, Mark K5XH
I used my 6400 in the RTTY roundup and it did a great job.
I also used my 6600, PGXL, TGXL and AGXL running SO2R with N1MM+ all worked great
Ian VE3JI
Hi Ian. I am trying to get RTTY working with the same set up as you just mentioned and wonder if we can take a configuration discussion off-line? I attempted to email you at your QRZ address but my message is bouncing back. My address is good on QRZ.
Randy
KH6XX
Viking Valiant, Hallicrafters SX-101A, HAL ST-6000, Model 15
Noisy for sure ... but still working since 1965
W7NGA -
Wow, that brings back a few memories! Glad it is all still working. I regret it now but I threw away my Model 15, a Model 14 typing reperf, and a TD unit years ago and went the computer route. Rig back then was a Central Electronics 200V and a 75S-3, TU was a homebrew "Mainline TTL" by Irv Hoff.
73, Mark K5XH
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 160 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 723 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
