How do you connect a computer using fldgi to a Flex 6400M
Exactly the same way you would connect to the 6300 :-)
The only thing you do not need to do is start up SSDR - it is adequate to only start up DAX and CAT and connect them to the GUI instance running on the front panel. That said, you may also operate the 6400M with the front panel disconnected (i.e. not yet connected), either initially, or by choosing "Menu"/"Radio"/"Switch version" from the front panel to disconnect it from the radio. You then operate exactly as if you had your 6300.
Thanks ! I will try that ! But will probably need to put a copy of the operating system in my computer! or will it install it on my computer from the 6500M>0
Not sure what you mean about operating system in your computer. The M has an embedded os that only runs the M version of SmartSDR, but can’t run fldigi. There has to be a standard computer to run fldigi under win10 or whatever. It gets connected to the flex through Dax/cat for the needed data. So MSmartsdr on the M radio, fldigi on the computer, and Dax/cat to connect the two.
You will follow the exact same procedure you used for your 6300. FLDigi needs to run on a computer, not the radio.
You do not need to open SmartSDR on the computer.
But, you will need to run DAX and CAT on your computer and associate them to the Front Panel of your 6400M.
Configure FLDigi the same as you did on your 6300 - select DAX Channels and CAT ports accordingly.
Then you control the radio with the Front Panel, but you control FLDigi from the computer.
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
