NUC and Panadapter issue
Rich
KQ9L
How are you connecting to the radio? Hardwired or WiFi?
Rich,
It is probably an issue with your network. Do you have the same problem if you connect your pc directly to the radio? A loss of the panadapter is because of dropped packets. Look at the network strength indicator in the lower right side of SmartSDR. If its not showing green bars, then that is a good indication of a problem with your network.
Update your video driver.
There was an issue with Intel IRIS video driver causing freezing panadapter/waterfall. You can search the Community for Intel Video driver.
Dave,
I had forgot all about the driver problem. Glad you mentioned it.
Thanks guys, sorry about the "radio silence" was hanging with the family. The Nuc is connected via hardware cat 6 cable to my home network, the radio is connected the same. I have found if I add a second monitor and keep SDR nearly full sized on the second monitor it works, but if I shrink it smaller than a certain size it does not work. I will search the site for Video drivers and report back.
Thanks.
Rich
I ran into a problem yesterday when I updated my Drivers on my NUC-I8 with the Intel IRIS Graphic 655 graphic chip and every time I brought up the Memory window (which I use a lot) it locked up SmartSDR.
I had to go back to the original 2018 Drivers for things to start working again so just make sure you check all features after you update the Video drivers and be sure you have a backup before you try it.
Yes, there are issues with some of the Intel video drivers.
As a follow up, I wanted to report to the group that I resolved my issue, sort of.
As many pointed out here, the issue is with the Intel graphics drivers. Even after I downloaded and installed the latest drivers my issue was not resolved. It was only after I disable the "hardware acceleration" and I was able to get everything to work, this is why I said "sort of". I would assume that eventually the drivers will be fixed but for now the Nuc is not running its graphics at full potential. That being said, frankly, I see no difference in waterfall / panadapter speed or responsiveness.
I hope this helps someone who may run into the same issue. Tim E at Flex was great and helped tremendously.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
