6600 rebooting by itself
Remote setup using SmartSDR 3.2.39 and most days I have SmartSDR running on my 2nd monitor even when I'm not operating. It's not uncommon to have it on all day. I have noticed (seemingly randomly) the software shuts down and I get an error window. I'm always able to relaunch SmartSDR and everything is fine.
A couple weeks ago I installed an IP camera in my shack so, if needed, I could see that status of various lights/displays in the shack remotely. Well today SmartSDR did it again and shut down with the error window. This time I quickly launched the camera software and could see the 6600 power light blinking. After a few seconds it went solid Green and I could again bring up SmartSDR.
Has anyone else had this issue. Again, it doesn't seem to happen very often and everything works as it should after the unintended reboot.
Peter - WB6POT
Peter
The software is crashing for some reason. I have opened a support ticket for this as it is a hardware/firmware issue.
M
@Peter WB6POT are you using the remote ON/OFF feature "REM ON"? if yes, try disabling it for few days and see if the reboots stop. This is assuming you're using it and have a relay connected to the REM ON port.
73' Frank - KP4IP
Frank - Thanks, & yes I do. I hadn't even considered that, but will give your suggestion a try after I track this problem a bit longer.
Peter - WB6POT
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
