6600 rebooting by itself
Remote setup using SmartSDR 3.2.39 and most days I have SmartSDR running on my 2nd monitor even when I'm not operating. It's not uncommon to have it on all day. I have noticed (seemingly randomly) the software shuts down and I get an error window. I'm always able to relaunch SmartSDR and everything is fine.
A couple weeks ago I installed an IP camera in my shack so, if needed, I could see that status of various lights/displays in the shack remotely. Well today SmartSDR did it again and shut down with the error window. This time I quickly launched the camera software and could see the 6600 power light blinking. After a few seconds it went solid Green and I could again bring up SmartSDR.
Has anyone else had this issue. Again, it doesn't seem to happen very often and everything works as it should after the unintended reboot.
Thanks,
Peter - WB6POT
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsPeter
The software is crashing for some reason. I have opened a support ticket for this as it is a hardware/firmware issue.
M
@Peter WB6POT are you using the remote ON/OFF feature "REM ON"? if yes, try disabling it for few days and see if the reboots stop. This is assuming you're using it and have a relay connected to the REM ON port.
73' Frank - KP4IP
Frank - Thanks, & yes I do. I hadn't even considered that, but will give your suggestion a try after I track this problem a bit longer.
Peter - WB6POT
