Waiting on Hardware Initialization Conflagration
This popped up when I started my Maestro last week.
I've tried everything from opening it up to check for loose connections (it's no longer under warranty) to trying to downgrade the radio to a previous version in the hope that the Maestro would reload firmware and everything would be OK. Nothing works - this message comes up ad nauseum when I try to connect to my Flex 6700.
Radio works fine with SmartSDR and no other issues, so I guess this may be going back to FRS on my dime.
Any ideas?
Eric NC6K
Hi Eric, I would submit a helpdesk ticket. Flex support is really good at diagnosing issues. They will let you know if it is something requiring a trip to Flex or not.
Len,
Thanks - I agree on the ticket. I figured I'd give it one try here first in case I was missing something obvious.
Eric NC6K
Check your 12 volts in. But yes, also open a Help Desk ticket.
I have the same screen with my Maestro. After messing around with the ethernet cable and rebooting my 6600M, now the Maestro says "Loading..." and locks up.
I get this all the time when I reboot the Maestro and my 12V voltage cable got kicked out.
Power cycle the Maestro with a good 12V supply and you should be fine.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
