Which Heil connector for Flex 6500 ?
Hi all
I want to use a Heil Pro7 headset with my Flex 6500.
Heil cannot tell me (strange) which connector is to be used, for a front end connection on the 6500.
Can anyone tell me please ?
Thanks + 73
Paul F6EXV
Best Answers
Still nobody that can confirm which connector must be used for a Flex 6500 and a Pro7 Heil headset ?
I do believe the front panel connector on the 6500/6700 are compatible to Yaesu microphones, so you can plug in a Yaesu microphone such as the MD-200 and it will work.
From the 6500 Reference Manual:
Thanks for your info, but I mentionned I want to use a Heip Pro7 connected to the front end of my 6500.
I am just trying to find out which connector to use : is it the CC-1-Y-8 ?
If you contact Heil, you need the Yaesu adapter for an 8 Pin Mic Plug (Foster) connector. Tell them it is for the Pro7.
It is the Yellow one (Yellow = Yaesu)
Bob Heil himself told me he does know, because Flex keeps modifying its plugs... And I had told him about the Pro7 to the Flex 6500.
Again, is it the CC-1-Y-8 ?
Thanks + 73
Paul F6EXV
Paul is correct on the 6500, How ever sometimes running High Power the Heil cable chassis ground is tied to the MIC - (pin 7) instead of Chassis ground (Pin 5) which causes RFI to be picked up when you transmit, Usually you can just reverse (pin 5) and (pin 7) on the radio side of the Heil cable if RFI is a problem.
On the Yaesu radio's the Heil cable is specifically made for, this makes no difference because they don't use the MIC - separately for a balanced connection like the FLEX does they tie the MIC - to ground in the Yaesu Radio's anyway.
Now I got it OK, the yellow cable !
Thanks a lot + 73
Paul F6EXV
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
