TX Band settings
I am using ver. 3.2.31 and a 6700 with a PGXL.. I set the RF power in the TX Band settings on each band so I don't over drive the amp but they do not have any impact on the output of the 6700... How do I save them so the output is set to the level I input on the chart.... On the TX window on the SET UP window the max. power is set to 100... does it over ride the 'tX Band settings?... If so, of what use are the TX Band settings?
73 Bruce AH0U
Hi Bruce,
here the same problem with Flex-6400 and V3.2.39. Please help
73 Uli, DF5SF0 -
Hi Uli,
What is the issue you are having? The maximum power setting is a global power limit, meaning the power will not exceed that amount on any band.
How are you measuring the TX power out after setting your desired power in TX Band Settings? If using the TUNE button, keep in mind that the TUNE power slider is not the same as the RF power out slider. You could transmit in FM with no TX audio to see the power out.
Was there a resolution on this issue?
I have just submitted a help desk ticket on this subject. I need to run full power on bands except 40m and 17m. 6600 with 3.2.39
Bill W9JJB
Bill,
elaborate - are you saying you need to run thr radio at 100 watts to drive a PGXL to legal limit?
Several things. What mode? What are you using for a wattmeter? What is the SWR on other bands?
It is NOT normal to have to use that much drive. Open a help desk ticket before you possibly do more damage to the amp.
The TX Band Settings Table SETS the power for each band and saves it in a Transmit Profile, but does not LIMIT the power on each band, nor does it prevent the power from being changed. If you change the power with the power slider on any particular band, the change will be remembered for that band, on that TX Band Settings table and Transmit Profile.
If you want to set a hard limit on Maximum power output, you need to set it in "Settings Radio Setup TX > Max Power" This is a global override that will limit the output on ALL bands.
DDUtil will still do power per band using AutoDrive tab.I just set it up today for W2ZMZ to have his Acom 2000a with older RCU be able to follow frequency of radio. Even if you bump up the power on the radio, next time you change to that band power is set to what is programmed in DDUtil.
What is the GEN shown in the TX Band Settings?0
Thanks Geoff: However---I am keying an amplifier and with no entry in the keying line TX1 the amp will not be keyed. For example, if I put the GEN to TX2...and all other settings point to key the amp which is TX1....nothing happens until I move the GEN to the same TX1 which keys the amp. I hope I described this......I only came to find this by experimenting with different selections in the TX Band Setting matrix.
Rog, WB8NDC0 -
Not near a radio now. But are you saying that unless you select TX1 for the GEN (band) that you cannot key the amp on say 20M?
If you are saying moving GEN to TX1 works then you are transmitting outside the amateur radio bands.
The GEN is for frequencies outside amateur bands (MARS/SHARES) and on the 6500/6700 requires a special TURF file. On the 6400/6600 it requires the extended TX module in addition to the TURF file.
If you are on 7.180 for example then the 40 meter entry in TX Band Settings would be what you want to change.
Dear colleagues,
In Smart SDR, the power limit on individual bands does not work. In the TX Band Settings table, there are fields for entering the power limit on each band. Unfortunately, this is only a theory. Will Flexradio improve this very necessary function to make it work?
Slawomir0 -
I believe Mike answered you. But from a user's perspective, the TX Band Settings table does not show per band power limits. It shows the state of the current TX profile. The band power limit is what you have adjusted it to in SSDR. Example 6 watts on 80m will be the limit until you change it. In this table it will show as 6. If you adjust to 20 then that is what you see in the table. Therefore it is working correctly. Changes are made with the RF Power slider for the band that you are on and is persistent. The table is not for power changing but to see the current state.
"The table is not for power changing but to see the current state."
True. But I sure wish the table form came with an option switch to keep the power settings, and not change when the power level is temporarily changed using that band. I know there was quite a discussion when this was changed a while back, i.e., to change or not to change. But an option switch on the form might satisfy everyone.
I could not agree more. The use of the table columns is inconsistent. The user can set on/off PTT Inhibit, ACC TX, RCA TX Req, and so on and that gives rise to the misunderstanding that a setting can be achieved with the RF PWR and Tune PWR columns but they are only for information with no setting functionality.
I do not think it needs a option switch though. Just type in the required power for a band, hit 'enter' and it is applied and visible, changing when adjusted again in the table or with the power slider / M model- Maestro PWR knob. That is how I would code it notwithstanding some reason in the software that prevents such a system.
i wish to use my amp Expert1.3k and change driving from 1 to 5W for full output. Change the RF Power is not possible, jumping back to 40 or 60W like a predefined default value. The result is always a shutdown of the amp because of overdriving. I would prefer to fill in the wanted value until i change it
again. Equipment Flex-8600M, Expert 1.3k...0 -
Me too. I would like to have maximum power limits I can set per band!
Initially, I also thought RF Pwr in TX Band Settings would set the maximum output per band, but it shows the current/last power setting, which seems a little pointless editing on this screen when you can just move the slider in SmartSDR or knob on the Maestro?
Rugged LDMOS transistors that are used in most amplifiers have a very high breakdown voltage and can withstand poor mismatch, (even a short circuit) on their output. What they can't cope with is overdrive on the gate/input. This is an easy way to **** a PA.
With that in mind, I always limit the RF power output from the radio so it is not possible to overdrive the PA by accidentally adjusting the power level. Icom radios provide a Max Power setting - I was looking for the same option for Flex.
Limiting power globally is not the answer for me. I have more than one PA and they need different maximum power inputs and some bands I run barefoot without a PA so need the full 100 Watts.0 -
Power settings are saved for every band in a Transmit profile. To save the appropriate power settings set a slice as the TX Slice. Tune to every band you want to save a power setting for and change the setting. After this is done save the Transmit profile.
With more than one PA, do the above for PA #1, save and then save a global profile. Repeat for PA #2 and save as another global profile.
I select the appropriate global profile for the amp I am using, in my case PGXL or Acom 2100S. I can then be certain that each band has a limit set for the amp being used. If you turn off automatic profile saving, any session changes will revert to the profile settings next time.
This has never gone wrong for me. The TX band settings feature is badly designed, being partly a set on/off service but partly only information so far as band power is concerned. I presume it has not deserved a re-think because profiles do the job more thoroughly and efficiently. I do remember though having to exercise my brain on to get the most out of profiles.
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
