Ability to select favorite GEN Band via Menu
Having a GEN Band would allow setting up a favorite SW station, BCB freq for Lowband antenna testing or even VLF work without upsetting the stored freq,band,filter, mode settings of the defined Ham Bands. Could someone from Flex comment if this is 'coming back' please.0
I do agree that I missed the general just for the sake of going there with some persistence as we have it now. I know when we have memories it will not be an issue.0
I have used GEN for LF, MF ham bands and also SWL. What about a MEM button too? Andrew de VK5CV0
Here is the issue. The "GEN" band has no standard definition like the 20m ham band in regards to international usage. So in the interim we have removed the "Gen" band. This is fundamentally different in SmartSDR as compared to PowerSDR as far as the internal workings. One of the fundamental internal building blocks in PowerSDR is the concept of a "band". In SmartSDR all a band really consists of is an arbitrary frequency range. So while it looks the same on the outside, it is not on the inside. In the future, we will be having internal discussions how "bands" and memories will work with the FLEX-6000 and interact with each other. I suspect that user definable "bands" may become a feature in SmartSDR in the future, but we have a lot of other things to address between now and then.0
Tim, I like the idea of "user definable" bands, complete with "band stacking registers" of a sort. Example... one could have a band definition form where the user could set upper and lower pan limits for the initial pan, as well as initial slice frequency(s), mode, filter, AGC, preamp, etc. (or use the last frequency used or saved on that "band.") You could allow three or four band stacking registers (or allow the user to specify how many in the definition form). then multiple hits of the "Band" button would toggle through the different preset band segments as per the definition form. For the "GEN" band, the user could define several band segments as above, perhaps being given the option of additional band definitions for this special button. As far as memories.... Individual memories could be utilized through a pull-down or pop-up list, or better, via a separate dockable/pinable panel that would have up/down buttons that would allow the user to scroll or toggle through a variety of memories. Banking or folders could be used to assist in sorting lists of "memories," which could essentially be handled the same way as the "Bands" -- storing slice frequency, pan upper & lower limits, mode, et. al. but in this case, the initial slice frequency(s) would be fixed according to the definition stored or edited. It would be especially nice if such a list could be edited and/or imported/exported as a Spreadsheet, CSV or text file or some other easy to edit document format in order to make large memory lists more manageable.... and sharable! Just a little grist for the mill. (for when it is time to discuss it)1
Tim, would it be possible to inhibit TX when the GEN Band button was selected??0
This is a great conversation that's separate from the main topic, so I created a new idea topic to continue the discussion. Please reference the new topic here: Defining Bands and Band Stacking0
Larry it isn't that simple. TX is already inhibited outside of the ham bands. It related to band persistence and what frequency ranges define a "band". This is well defined and basically overlaps nicely for hams based on the IARU defined band plans. It is not so well defined for other "bands". We chose to remove the "GEN" button until we make a decision on how to handle non-ham bands in the software. It is just a temporary change.0
Got it Tim..thanks.. Im OLD..I like to think simple :-) Too many years of deep analysis/ troubleshooting have burned me out!0
In the TX Band Settings, on all the Bands have a check on the column titled RCA TX1...on the row titled GEN I did not place a check under RCA TX1...and my amp was not keyed......when I placed a check on the row titled GEN and column RCA TX1, I was able to key the amp. I only found this out after several experiments. 90 percent of my operation is on SHARES frequencies. On the row titled GEN I have a RF PWR and Tune PWR value other than that nothing else is checked except the column titled RCA TX1. Have a 6400 and run V3.4.24. Tim, if you are reading...this...I trust there is a reason why I am experiencing this.....while I am here a fellow SHARES and MARS operator in CO with his 6700 is experiencing the same issue. Regards, Rog, WB8NDC/NNB5UX0
SHARES and MARS are out out amateur bands, therefore you need to use the checkbox for General.
@RogerG, I assume (if you have the 6600/M) that you have the extended transmit filter board and have received and run the new TURF file executable from Flex to fully open up your radio? Once my 6700 TURF file was running I had all bands open.
John: When I ordered the Flex 5400 (not the M) Flex performed the mods for general coverage for both transmit and receive before shipping to me.0
John: Shucks....made a typo....I own the Flex 6400 not the Flex 5400(not the M)......sorry.0
David: Thank you. I read your entry. What I cannot figure out is where in the manual did you learn this?
Rog0 -
It is to me common sense.
Traditional transceivers when opening them up for MARS it was known as “general coverage transmit”. You were the able to operate outside amateur bands.
Since the TX Band Setting table has entries for each amateur band, the general row must be for frequencies outside amateur bands. If it were for general coverage receive only there would be no need for it.
Just how I would interpret it.
73 Dave wo2x
David: Thank you for your entry. Apparently, I don't have common sense..which is why I asked the question and you have not answered it. I am not interested in an interpretation. Allow me one more time--where in the manual will it answer my question please. Thank you in advance, Rog, WB8NDC0
It does not.
Any transmit frequency not in an amateur band would be covered by the GEN settings.
David: Thank you for your reply.0
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
