Two 6600's, two PC's one Router and no Harmony
Check the slice master documentation. You can force it to connect to the radio of your choice. Once you do that, you can have 2 different shortcuts, one for each radio.
--radio-filter FILTER FILTER is a string to choose amoung multiple radios at start up. Like filter.txt. --radio RADIO IP Address of the radio to connect to. For use on a routed VPN only. --station STATION Name of Multi-Flex station to bind to.0
Hi Joe, on the last tab of Slice Master is a radio chooser. I think that if you choose one radio on one computer and the other radio on the other computer you will get what you are after. You need to scroll all the way to the bottom of this tab to find this option.
Hello Len,
Thank you for replying. I had that down. What was surprising is that it did not default their the next time. And once corrected, the slices program would open but then quickly close.
The same PC seems to be having an issue with SmartCat as well. Don't know they are related but may have to open a trouble ticket to see. Again thank you for answering. Have a Happy Thanksgiving.
Oh, OK. Yes, it sounds like a help desk ticket is the right thing to do.
Happy Thanksgiving to you too!
The help ticket cleared up some issues I was having. Very quick work on Tim's part. I still have a issue where while I can choose the radio, Slicemaster sees the other PC. Ultimately what I have to do is shut down the other PC. Once done, Slicemaster recognizes the only operating PC on the network. Is there a way to have Slicemaster only recognize the PC it is installed on?
Thank you
Thank you Mike, that was helpful. Still having it cross over occasionally choosing the right radio but on the other PC. Going to dig further.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
