Installation of FreeDV fails
Mike24
Member ✭
Hi there,
I use a Flexradio 6400 with v3.2.39, and Windows 8.1. SmartSDR_FreeDV_Waveform_Installer.exe has been installed. In SmartSDR I can install a new waveform FreeDV v1.05.
(It sounds strange for me that the file is from 2015. Is that correct? Could that be?)
That's all for the success and the current positive results.
The following does not work:
- SmartSDR FreeDV Waveform does not find a free slice A, it reports with:" No Free DV Slice"
- I have no FDV mode in the menu
What is my mistake?
Thank you for any hints and tipps.
DL2MHB
What is my mistake?
DL2MHB
In the meantime the support returns to my inquiery. FreeDV as wavetime integration is not supported any more. The solution is to use FreeDV as a third party application and connect the SmartSDR via DAX.
Mike, DL2MHB0 -
Mike, there have been some GREAT strides in solving this problem, and we are testing that out right now, as I type. So, if you get the time to check in with us on the FreeDV QSO finder sometime at qso.freedv.com, I can provide a lot more detail on how this is working.
All the best,
Walter/K5WH2
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
