Installation of FreeDV fails
Hi there,
I use a Flexradio 6400 with v3.2.39, and Windows 8.1. SmartSDR_FreeDV_Waveform_Installer.exe has been installed. In SmartSDR I can install a new waveform FreeDV v1.05.
(It sounds strange for me that the file is from 2015. Is that correct? Could that be?)
That's all for the success and the current positive results.
The following does not work:
- SmartSDR FreeDV Waveform does not find a free slice A, it reports with:" No Free DV Slice"
- I have no FDV mode in the menu
What is my mistake?
Thank you for any hints and tipps.
DL2MHB
  • Mike24
    Mike24 Member
    In the meantime the support returns to my inquiery. FreeDV as wavetime integration is not supported any more. The solution is to use FreeDV as a third party application and connect the SmartSDR via DAX.
    Mike, DL2MHB
  • K5WH
    K5WH Member ✭✭
    Mike, there have been some GREAT strides in solving this problem, and we are testing that out right now, as I type. So, if you get the time to check in with us on the FreeDV QSO finder sometime at qso.freedv.com, I can provide a lot more detail on how this is working.
    All the best,
    Walter/K5WH
