DAX and CAT
Any chance we could get the option to minimize the DAX and CAT windows to the system tray. Once they're set you really don't need to look at them again.
They just clutter up my work flow.
Hi Dennis, mine are minimized unless I restore them. I think if you minimize them, they should minimize automagically next time you start SmartSDR (assuming that you are using SmartSDR...).
I am not talking about simple minimize. I am talking about permanent placement in the System Tray.
You can still EASILY click on it to change settings. It's just completely out of the way. You never EVER need to see DAX or CAT after it's set up. I use ALT-TAB to scroll and select my app. DAX and CAT are just clutter. I know this is a complicated suggestion, but coders know how to do this.
Same goes for this. Why is it there? It's does absolutely nothing. It's clutter.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou mean like this?
Here is a list of them. Pick one you like. Just don't forget you did it when you can't find it.
https://www.maketecheasier.com/send-windows-programs-to-system-tray/
And, while you are at it, check out Window Virtual Desktops. I use this all the time. I have work windows and ham radio windows.
