No RF on Transmit
KA0B_Bill
I have gone through setting up CAT and DAX to run with N1MM. Since doing this I no longer have manual control to Tx RF on the Radio Panel using MOX button. I do have the capability to Tune with RF through the Radio Panel. I have disabled the CAT serial ports. I did a Radio reset to no avail.
I know I had tried tuning on 80m and the shows ~2.5 SWR on Tune power, external LDG tuner, on 40m dipole. But it will not Transmit. Is there another reset for RF output? Is there another Transmit enable that may have been disabled?
Flex 6400, SmartSDR 3.2.39
Thanks in advance.
KA0B
Thanks in advance.
KA0B
Can you post a screen shot of SmartSDR please.
Thanks for the screen shot. It is very helpful.
For N1MM, it only communicates with CAT Ports and you do not have any configured in SmartSDR CAT.
If you follow this document it will work wonderfully for you.
https://www.flexradio.com/documentation/flex-6700-so2r-configuration-n1mm/
Thanks Mike,
I will work through this, hoping this also fixes my issue of the Manual operation issue. I know I did have something setup talking to N1MM, but it showed an error when getting the snapshot and deleted that entry. I'll let you know what happens.
Bill - KA0B0 -
OK, that seems to have resolved the issue. Thanks a bunch.
73's Bill KA0B0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
