Connecting(?) USB to Serial adapter for the FLEX-6000 series to SainSmart USB 8 CH relay board
Bob KB8BYW
Best Answers
If its the USB version of the sainsmart relay board then it plugs directly into the flex usb port, you use the flex USB CABLES under settings to configure it.
This is the relay board I purchased, SainSmart USB Eight Channel Relay Board for Automation - 12 V https://www.amazon.com/dp/B0093Y89DE/ref=cm_sw_r_em_apa_glt_i_Y3579B59D0VDSDA4CM5Z?_encoding=UTF8&psc=1
Larry, I have a cable like the one you shared, so it looks like I may be ready to use this relay board after configuring git under settings! I will report back in after trying to set it up!
Thank you all!
Bob, KB8BYW
Hi Bob, I think the board that you have requires a computer, Raspberry Pi, Arduino, or some other dedicated solution between the board and the Flex to make it work. I don't think that it natively takes Flex API or CAT commands to change the relays.
An Arduino or Teensy would be a cheap solution but would require programming. A Raspberry Pi could be used with Node Red and would require programming, but the Node Red support here and in the nodered-hamradio io-group is fantastic. There may already be a solution for this - you would need to look at what is available.
The other way to go is a relay board that has an individual control line for each relay. Then you could use the USB to parallel cable that Flex sells.
Thank you Len, thank you Larry. I will need to look into this a bit deeper. I saw the video that Mike VA3MW made, and thought all I need is a relay board and the cable he mentioned, and I’m in business. Thanks again guys!
Bob, KB8BYW0 -
I have the sainsmart USB relay board and all I use is one of these cables. maybe give us a link to the exact sainsmart board your using. The USB to Serial cable in the video is used for a differant application than what your tryin to do.
So, I think I have a misunderstanding... Larry, does the SainSmart board plug directly into the Flex or into a computer that is plugged into the Flex using a different USB port? In other words, do you need a program on the computer to drive the relay board?
Thanks Larry, I didn't realize that the SainSmart protocol was in the Flex (or that the Flex protocol is in the SainSmart...). So Bob, ignore my answer and go with Larry's.
😃 Success, the relay board works after help from Larry and Len! Thank you both for taking your time to help me with my issue! I am smiling ear to ear! Take care guys and I hope only good comes your way!
Bob, KB8BYW
Thanks Bob. The credit all goes to Larry. I did not understand that the board would work by directly connecting it to a Flex USB port.
In any event, I am glad you got it working!
Hi Len, Yes, Larry was able to answer all the questions! Because you asked Larry for information, that in turn helped me solve my issue. That’s why I was thanking you both! I am lucky y’all were out there, and willing to assist. Thanks again, take care, and happy holidays to one and all!
Bob, KB8BYW
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
