Maestro and CAT
Slawomir
Slawomir Member ✭✭
Hi,
I usually work on my Flex-7000 with SmartSDR. I have configured several CAT ports to support the logging program and work on FT8. But sometimes I work on Maestro, then I miss the ports in CAT. Can I work on Maestro using ports installed in CAT?
Slav.
    If I understand your question...
    Yes, you can operate using the Maestro and then run Smart CAT on a PC for other programs such as logging. This is a big advantage over other HF radio technologies.
  • Slawomir
    Slawomir Member ✭✭
    Hi thank you for your quick reply. Tomorrow I will try how it works. This is indeed an advantage over other SDR devices.
    73's
    Slav.
