TGXL - Error "NO PTT IN"
Hi there,
The day I have to send back my 6600 for repair I receive my TGXL and Antenna Genius (SO2R)... Thanks Murphy. I "wire" everything they way it should (outside in)
Antenna 1-3 into the Antenna Genius
AG A to Antenna A port on the TGLX to the Antenna port A on the PGXL to coax run up to the shack
AG B to Antenna B port on the TGLX to the Antenna port B on the PGXL to coax run up to the shack.
Coax run A is plugged into my backup radio. PGXL stays in standby mode.
TGXL port A is selected and Antenna Genius port a is selected.
I add 20 watts of RF and get an error saying "no ptt in" on the the TGXL display... even in bypass mode. But also in OPR mode.
What am I missing?
Thanks!! Josh - N0EG
I created a support ticket for this.
Cool thanks Mike! You guys have great support!
Josh-N0EG
Your TG-XL Utility (under Settings-> FlexRadio tab) PTT Source set to LAN?
I open ticket 2 weeks ago for exactly the same error and so far did not received solution or commitment. Discovered issue during CQWW DX SSB Contest, it is intermittent and I lost quite a few QSO when had to release and hit the foot switch again to reactivate TX.
I did not have chance to test it in other modes for a long period of time to see if it the intermittent interrupts.
Sergey
kn7k
@kf4HR, No. The Flex settings are disabled as right now my 6600 is in the shop. So I was hoping to RF sense the signal coming from an 857.
There is no RF sense substitute for PTT. You must have a PTT live or LAN connection from the radio
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
