updated to 2.7.6 from 2.4.10 --- getting CAT error on startup
Title says it all
Radio is good, so is DAX, profiles seem all good. Just CAT errors out on startup with unhandled error.
opened a ticket, but won't be seen until Monday - ish
anyone seen this and fixed it ? I'm taking on vacation starting Sunday and hoping to do some digital fun. CAT would be nice to have
happened on two machines both Win10
If you have not fixed this yet, please open a support ticket. For issues such as this, that is your fastest road to a solution.
I did open a ticket on Fri night in case someone else had run into it, and first thing Monday morning, Ken NM9P emailed me and started working on it.
a few hours, few emails, a call and a Team-viewer session, Ken had nailed it. this was a Surface and my Dell laptop at home had the same problem which I was able to fix after Ken explained what he did to fix it.
The CAT drivers couldn't load for 2.7.6 because 2.4.10 could not be removed even manually.
After un installing all the previous versions, he installed 2.4.10, then uninstalled clean and re installed 2.7.6 and that worked.
I followed the same process on my home laptop remotely and that now works like a charm too.
Thanks Ken ........... all is right in the Flex world again .....
Rich
n2ry
Thanks for the update, Rich. It really helps to see the solution to problems published here.
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
