My 2 month old 6400M Loses Audio
My 2 month old 6400M loses audio when I select 12M on the band selection buttons.
No PC connected to radio, connected to my network, running V3.2.39
When selecting 12M, I get a message on screen that Ant may no be changed when Transmitting. And Audio stops.
I also notice that the Rec Ant is on 2 and the Xmit Ant is on 1, when I had set it to Ant 2.
If I press 12M again the audio will generally come back.
Craig
That does sound unusual. Can you take a picture of your screen and add it to this dialogue?
It could be that your AGC-T settings are set to Zero.
Is there some other application that could be sending a transmit command to the radio?
The other option is that you may want to do a radio reset after you backup your profiles.
Problem solved with a reset. Thank you
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
