Direct connection from Maestro to 6600
I am trying to track down some birdies in my receiver. I plan to cut all power to the house and then turn circuits on one by one to find the offender.
I am running the 6600 and Maestro off battery power and I planned to make a direct connection from the Maestro to the 6600, eliminating any router or switch which runs on house power.
I can't get the Maestro to see the 6600 when I use a direct connection. The Maestro comes up and asks me to choose a WiFi Network.
I have used the ethernet cable I normally use for the radio directly to the Maestro and made sure I was NOT in the mic connector. I've tried booting the radio and Maestro in different order without success.
What am I doing wrong?
73, Pat KØPC
I found the problem. I was running the Maestro on the internal batteries, not plugged into separate power. I now remember reading somewhere that the ethernet connection is off when running on batteries.
Yep, that is it. Glad you figured it out.
My phone's Ethernet is happy to run all day, and I get the option to shut if off if I want. Why can't Maestro match that?
73 DE AA6E
Out of curiosuty which phone do you have that connects to an Ethernet cable? Are you using an OTG adapter?
Misspoke - does a live Ethernet take so much power? Obviously it will shorten a battery session, but I could imagine wanting Ether on battery for testing, etc. Warn the user about discharge rate. Even better, show battery time remaining on a meter.
A normal laptop manages all this.
- 346 Community Topics
- 612 The Flea Market
- 7.9K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 409 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 21 Aurora
- 202 FLEX-8000 Signature Series
- 919 Maestro
- 891 Genius Products
- 453 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 754 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 973 Third-Party Software
