Direct connection from Maestro to 6600
I am trying to track down some birdies in my receiver. I plan to cut all power to the house and then turn circuits on one by one to find the offender.
I am running the 6600 and Maestro off battery power and I planned to make a direct connection from the Maestro to the 6600, eliminating any router or switch which runs on house power.
I can't get the Maestro to see the 6600 when I use a direct connection. The Maestro comes up and asks me to choose a WiFi Network.
I have used the ethernet cable I normally use for the radio directly to the Maestro and made sure I was NOT in the mic connector. I've tried booting the radio and Maestro in different order without success.
What am I doing wrong?
73, Pat KØPC
I found the problem. I was running the Maestro on the internal batteries, not plugged into separate power. I now remember reading somewhere that the ethernet connection is off when running on batteries.
Yep, that is it. Glad you figured it out.
My phone's Ethernet is happy to run all day, and I get the option to shut if off if I want. Why can't Maestro match that?
73 DE AA6E
Out of curiosuty which phone do you have that connects to an Ethernet cable? Are you using an OTG adapter?
Misspoke - does a live Ethernet take so much power? Obviously it will shorten a battery session, but I could imagine wanting Ether on battery for testing, etc. Warn the user about discharge rate. Even better, show battery time remaining on a meter.
A normal laptop manages all this.
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
