HIGH SWR RFP
I am having problems with the PGXL on 160M. I get the above error message that I don't see in the manual. The SWR is not high but my blood pressure is getting there.
I also get the PGXL Utility disconnecting constantly.
Both are happening at very low power output, less than 10W drive and low SWR. With amp on standby the 100 watts from my 6400 is having no problems.
I am using SSDR 3.2.39 and PGXL 3.6.21.
The antenna is a double L on a yard arm at 68 feet and 4 feet from my 70 foot tower and resonant at 1.830 Mhz. Feedline is LMR-400.
I had RF common mode problems and put a coaxial balun at the feed point which removed most of that and ferrite on the shack end.
I have used up all of my ferrite clip-ons and tried it on every wire in the shack.
Any help out there on this?
Robby/HP3SS
I just got the same issue tonight. Whats up?
I would suggest you open a Support Ticket. When a friend and I were Beta testing the PGXL we had the same issue on 160M. Only 160M. Same antenna configuration as yours. With low drive levels. With the antenna showing actually a very good SWR. The PGXl would immediately fault with the High SWR warning. At that time we could communicate directly as we were part of the Beta testing group. The application of common mode chokes on both the input and output of the amp was tried with no improvement. After several remote sign on sessions with the development tech some setting were found on the SWR sensing that corrected the problem. At that time it took several months to resolve but I suspect it would be much quicker now since our issue was about 3 years ago.
John K3MA
This needs to be looked at by the support team. They have a few things that they can do for you.
Thanks Mike. I will open a ticket.
Robby
I had the same problem this morning on 20M running FT8. It happened 3 or 4 times. Each time it corrected itself for the next transmission. My SWR is 1.15.
Gorden
Please open a support ticket.
The PGXL does an amazing job of finding SWR transients that you can't really see with any other test equipment due to the speed it works at.
Your SWR can rapidly change at high power for many reasons, such as a flash over at the antenna and/or baluns. The quick test is to see if you have the same problem on a dummy load.
BTW, 2KW dummy loads are not expensive and everyone should have one. DX Engeineering has them.
Anyway, please open a ticket.
Getting the HIGH SWR RFP error everywhere except 160M.
I need to get this fixed or face a firing squat from my contest team.
Robby
If you are still having the issue, please respond to your support ticket.
The support team does not have time to monitor the community.
I can do the team viewer anytime starting now.
Robby
Sorry. I have been busy with antenna and health problems.
Dan: Thank you for your time and attention to my issue. Everything is going good now.
I would like to close the ticket if you are ready.
Robby/HP3SS
Robby, so what did you find that was causing the PFP fault?
My LMR-400 that was feeding my SteppIR had a break in the center conductor that intermittently opened and would cause an SWR spike. At least that's what I think it was. I found two breaks in a 100 foot run. I can't climb anymore and the guys that installed it had never seen any coax newer than RG-8 so maybe there were some tight turns. It was hard to find the bad spots. I think I will go back to RG-213. It's way more FLEXable.
At any rate it was not the PGXL. The amp is fine. Dan at Flex spent about 90 minutes on the phone helping me.
He is a real pro.
Hello,
Forward to November 2025. New PGXL-3. High SWR on PGXL screen.
Latest FIrmware on 8400M and PGXL. Calibrated 1KW dummy load. Keyup 10 watts tune, shows SWR 1.01 on PGXL screen. High SWR on PGXL display. Same happens into a resonant 20m vertical. Opened support ticket. Advised full factory reset. Completed full factory reset, same high SWR alert on PGXL display. SmartSDR on PGXL panel shows no power output, and approximate temperatures. The PGXL popup shows no voltage or temp. in lower right corner. The display on the PGXL does show 36.5/31.1c, Vdd 30.0v, Vac 244v.
I would really appreciate it if that development tech, if he is still around that helped John, K3MA in October of 2021 that changed the settings in the SWR sensing which corrected the problem, perhaps could correct my problem.
I love the 8400M and TGXL. Im not so sure the PGXL-03 likes me, 😅hi, hi..
Bob Shipton, K8EQC,
Tucson, AZ
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 278 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
