White Power Light
@awosha , take a look at this link. I think this might be a good solution to your problem. Also look for videos on YouTube from Mike, VA3MW. He has taken remote operation of Flex radios to a whole new level and provides insights that I have incorporated into my station that make it very usable remotely.
After a power failure, you will have to push the power button to power the radio back up. This is by default and is working as designed.
The Remote setting controls the RCA REM connector on the back of the radio.
REMOTE POWER ON INPUT
This RCA connector is provided for remote power-on functionality. When the Remote Power ON feature is enabled, shorting this input to ground will activate the radio - opening this connector will disable power on the radio. Refer to the SmartSDR documentation for information on how to configure this input. (Note: 3.3VDC Max Input.)
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
