Can You Import A Manually Updated Memory CVS File W/O Issues?
w1smc
I have a bunch of frequencies I’d like to manually update in an exported memory CVS file and then import it back via SSDR.
Would this be a problem?
You can give it a try.
Well I went into an exported memory file and edited it using Excel ...
I added 1 line at the bottom by copying an existing line and changed the frequency & mode information.
I then imported the file and selected the entry I added.
The radio changed to the selected frequency. However, no filter selection was made. I had top manually select a filter to hear the stations on LSB.
I figured it out ...
Change the RX_FILTER to -2800 ...
Re-imported and all is well in Mudville ...
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
