Can You Import A Manually Updated Memory CVS File W/O Issues?
w1smc
I have a bunch of frequencies I’d like to manually update in an exported memory CVS file and then import it back via SSDR.
Would this be a problem?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou can give it a try.
Well I went into an exported memory file and edited it using Excel ...
I added 1 line at the bottom by copying an existing line and changed the frequency & mode information.
I then imported the file and selected the entry I added.
The radio changed to the selected frequency. However, no filter selection was made. I had top manually select a filter to hear the stations on LSB.
I figured it out ...
Change the RX_FILTER to -2800 ...
Re-imported and all is well in Mudville ...
- 683 The Flea Market
