Can You Import A Manually Updated Memory CVS File W/O Issues?
I have a bunch of frequencies I’d like to manually update in an exported memory CVS file and then import it back via SSDR.
Would this be a problem?
    You can give it a try.
  • w1smc
    w1smc Member ✭✭
    Well I went into an exported memory file and edited it using Excel ...
    I added 1 line at the bottom by copying an existing line and changed the frequency & mode information.
    I then imported the file and selected the entry I added.
    The radio changed to the selected frequency. However, no filter selection was made. I had top manually select a filter to hear the stations on LSB.
  • w1smc
    w1smc Member ✭✭
    I figured it out ...
    Change the RX_FILTER to -2800 ...
    Re-imported and all is well in Mudville ...
