BCD to OM6BPF
Roland HB9VQQ
The Flex USB Guide is missing the instructions to connect the USB Port of the Flexradio (6600 in my case) to the 15-Pin control Port of the OM6BPF.
- Reqiured cable: USB FTDI Part Number C232HM-EDHSL-0
- 15 Pin Male D-Sub Connector (OM6BPF Backpanel)
Hope this helps in case you need it.
Hallo Roland
habe gar nicht mitbekommen,dass Du auch einen Flex hast.
Sei gegrüsst, 73 de Manfred, HB9FLU
Hallo Manfred, seit meinem 50 geburtstag einen 6600 :-) Du auch ? Gruss Roland0
Ну теперь все понятно0
Hi guys, which one is a ground one (#10)?? At FDTI website, I've found black one is actually ground...?
Thanks in advance.
73s, DK8ZZ0 -
That is how I use it.
Alan. WA9WUD
So, here is an answer (actually the first post is a right one :-)
PIN 9 orange
PIN 10 yellow
PIN 11 green
PIN12 brown
PIN 15 black (ground)
USB cable setup:
Change: BCD
Source: TX Antenna (ant 1 or ant 2, which one you need)
Type: HF_BCD
Polarity: active high
73s, Zik DK8ZZ0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
