Loss of receive unless I switch TX to unused antenna port
Hello, I opened a ticket with this issue today. Posting here to see if anyone has come across this issue:
Flex 6700, Software 3.2.29. Windows 10 or Maestro (happens on either interface)
I only have one antenna currently plugged into ANT1. I noticed particularly bad receive performance today but had no problem transmitting with low SWR. After messing around with the radio for a while, I discovered that if I switch the TX to ANT2 while keeping ANT1 selected with RX, I get full RX performance back.
THERE IS CURRENTLY NO ANTENNA CONNECTED TO ANT2 AT ALL.
I have attached screenshots of the difference.
Things I have tried:
-Factory reset
-Recreated the issue with Maestro, not just SmartSDR.
-I moved my antenna to ANT2 port. Then the problem happens in reverse. I cannot get good receive performance unless TX is selected on ANT1.
I have experienced something similar. But I think the explanation is how the RX Ant 1 is getting it’s RF pre-amplifier set higher when the TX is switched to another (in this case unused) antenna.
Please check your slice’s RF pre-amplifier setting to see if you can make it higher and amplify the signals you are receiving on Ant 1.
Hi John, yes this doesnt seem to be helping. The ANT1 jack is completely dead, even with RF Gain all the way up, unless I turn TX to the unused port. IT must be something gone wrong with the relay circuit...
If a reset of the radio does not resolve your issue, it sounds like you have a hardware issue with the radio.
You will need to open a support ticket. If you do, please include your screen shots as they are very helpful.
Hi Mike, I did open one yesterday with the screenshots. I'm waiting for a reply from someone. Thanks!
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
