SmartCAT & DAX questions from a Flex newbie
There are a couple of things that I'm having trouble puzzling out from the documentation. Perhaps these will become obvious when I actually have the new transceiver in front of me...but I'll go ahead and ask now.
1. With a 6600, is it customary to have sets of COM ports defined for just slices A and B, or should I be planning to create sets of COM ports for four slices? (I'm thinking use cases such as chasing a DXpedition simultaneously on two bands, both working split; or SO2R operation in a phone contest, where I might want to operate split on 40m and/or 80m while also active on some other band.)
2. I enjoy playing in contests SO2R. If I want "normal" SO2R audio, including the ability to toggle stereo audio from both receivers, or select mono audio from one or the other, am I correct in suspecting that DAX is not the right tool to pass audio -- I'd need to listen to the output from SmartSDR if using a headset attached to my computer, or use a headset plugged directly into the transceiver? (I currently have three headsets in service in my office/shack -- one for my work computer, one for my shack computer, and one for the radio. I'd love to simplify that.)
These next two questions aren't specifically SmartCAT/DAX related...but while I'm asking probably dumb questions....
3. I'd love to be able to play in a contest, with N1MM running on one computer, CW skimmer generating spots on two bands on a second computer (to take the processing load off the N1MM computer), and still have the ability to make use of the controls on the 6400M itself at the same time. Is this possible, or is the 6600M limited to two points of control / would I have to run SmartSDR on the contest logging computer for controls beyond N1MM macros? (Also, is Slice Master the preferred way to feed Skimmer, or is DAX sufficient?)
4. Regarding the built-in antenna tuner: does each antenna port have a discrete set of tuner memories, or is it a common set of ATU memories applied to both antenna ports? (For example, let's say that I had an antenna resonant at 7010, and another antenna resonant at 7290; could I avoid having to retrain the ATU every time I change antennas if I only used the 7010 antenna on ANT1, and the 7290 antenna only on ANT2?)
Thanks.
I’ll leave it to others for some answers, but basically DAX is to pass audio to other software, ex. FT8. Best result for listening to audio is plugged directly into the radio, either headset or powered speaker. The pc (speaker or headset) can be used with the “pc audio” control, but is subject to processing delays of windows, maybe 1/2 second or so.
Hi Mike
We have a number of videos that might help you out on YouTube https://www.youtube.com/user/FlexRadioSystems/videos
Here are some of the popular ones:
Introduction to SmartSDR for iOS https://www.youtube.com/watch?v=UTntWjSUn0c
Microphone Connections and Setup https://www.youtube.com/watch?v=GdFeTzPo14w
SmartSDR WSJTx Setup https://www.youtube.com/watch?v=vxageEY7-Pw
Flex 6000 Receiver Tuning - How the AGC-T works https://www.youtube.com/watch?v=-WUWuAS24uM
How to use your friends Flex 6000 Series radio -- remotely https://www.youtube.com/watch?v=iEctXuWBHME
Using the USB port on the back of the 6000 series radios https://www.youtube.com/watch?v=T7bia-pZbBU
Setting up CW Skimmer! https://www.youtube.com/watch?v=ydTfqOkjafs
SmartSDR CAT & DAX - in depth https://www.youtube.com/watch?v=RXeMMayB3-o
Mike's FlexRadio remote HF Station https://www.youtube.com/watch?v=_QxapW0bMLc
Configuring your Transverter! https://www.youtube.com/watch?v=xJ5fIe0bWDE
Introduction FlexRadio Home LAN Networking https://www.youtube.com/watch?v=tKfETuCBukQ
Introductory SmartLink setup https://www.youtube.com/watch?v=kMbi3dAiMi0
FRStack & GridTracker how to chase DX and grids https://www.youtube.com/watch?v=4LcIM1jSdrM
SliceMaster and WSJTx for FT8 and other modes https://www.youtube.com/watch?v=_ww8CcGNAzg
Setting up my First HF Remote Station https://www.youtube.com/watch?v=C7d5C7nc5R0
Flex 6000 radio and FRStack https://www.youtube.com/watch?v=M5gxKUDlzeM
Configuring N1MM+ to work with SmartSDR https://www.youtube.com/watch?v=7Lql8RReUvA
Understanding FlexRadio's S-Meter readings https://www.youtube.com/watch?v=GQdjoY91pyY
-1
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
