TGXL does not follow active TX slice
My TGXL is not following the active TX slice. I have the Flex6600M, PGXL and TGXL (SO2R version) and run SmartSDR on my PC and use N1MM+ logger. When I have 2 slices open on separate bands and I change the TX focus in N1MM from one band to the other, the radio follows the requested band change but the TGXL does not follow. This is easy to see since the tuning solution doesn't change to the new band. It is only after I start to transmit that the TGXL changes to the tuning solution for the new band. So, when I start to transmit on the new band I sometimes get the high SWR warning from the PGXL since the TGXL hasn't changed its tuning solution in time.
I've opened a ticket for this, but I'm posting here to see if anyone else has seen this behaviour. I'm wondering if there is some configuration setting that I'm missing.
I have had the same problem. I have resorted to manually tuning to a solution.
If you set TX delay to at least 20 ms the Tuner Genius will change between A & B side before transmit power is applied.
The TG XL manual specifies the minimum TX delay.
Hi Dave,
I've actually set the TX delay to 100 ms hoping to avoid the high SWR warnings. In N1MM, when I hit the right or left arrows to change bands, the radio changes TX focus, so why doesn't the TGXL also receive this command and set its tuning solution for the band and frequency that the radio has TX focus for? This is what I would like to know.
I've found this to be pretty straight forward. With my TG-XL memories set properly, my TG-XL tracks my 6700 slice/band changes perfectly. But if I don't have a particular band or band segment saved in the TG-XL's memory, it will not auto-band/frequency change.
KF4HR
Dan Quigley, N7HQ, connected via Teamviewer to my station last night and solved my problem. As it turns out, I had high packet loss on my LAN (well over 1%). Disabling the so called green mode on my PC NIC and in my Cisco switch eliminated the packet loss. I was likely getting the high SWR warnings due to excessive delays on my LAN due to this high packet loss.
Concerning the TGXL not changing its tuning solution when changing to the other radio on another band until you start to key the transmitter, Dan explained, if I understood well, that this was by design to deal with multiflex, where 2 different stations could be active on different bands, both on their slice A. Currently, the TGXL doesn't know if both radios are being used locally in SO2R or if it is a multiflex situation. It looks like they are investigation a solution for SO2R operation that would allow the TGXL to track the active TX slice locally.
Finally, I wanted to thank Dan and the Flex team for their outstanding support.
73, Les VE3NNT
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
