Flex6400M: Only gets Connection (Waterfall/Receiving) after second reboot
Hi,
i have to restart my 6400M always one mor time after i switched on the radio, to get full access to the receiver. Waterfall is "black", Spectrum visible, but no incoming signals to see or heard.
After the Restart all is OK.
73', Stefan
    This would be best resolved by following up with a support ticket. They can help you out.
    https://helpdesk.flexradio.com/hc/en-us/articles/202118688-How-to-Submit-a-Request-for-Technical-Support
  • snet0311
    snet0311 Member ✭✭
    Hi Mike. Unfortunately it was not possible to sign in for a ticket without a registration for the „Technical Support“ first. I did‘t find any option to register. So i‘ve done some further research about the problem. It‘s solved! The powering up and down with a delay was the solution. Done so, now it‘s working. 73‘, Stefan
    Yes, you will have to register to log a ticket.
    Upper right corner
    Next
  • snet0311
    snet0311 Member ✭✭
    The Devil is in the Details. „Sign In“, „Sign Up“ first 🥲😉
  • Franksr-N9GQR
    Franksr-N9GQR Member ✭✭
    I just was receiving all red in place of my water falls on 20m and all
    black on 40m?
    Hi Frank, I would suggest that you export your profiles, then do a factory reset. If that doesn't help, submit a help desk ticket.
