RX ANT - A Output Can an Antenna Analyzer be Applied to It?
Craig Gagner
Hi Flex Community,
Can a VNA or Antenna Analyzer be run through the RX ANT - A or B output. Do these ports have a direct signal path to the respective antenna when LOOPA or LOOPB is deployed?
w7phg
It should work. Give it a try and make sure you don't transmit and your RF power is zero.
Thanks Mike;
I heed your advice.
w7phg
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
