RX ANT - A Output Can an Antenna Analyzer be Applied to It?
Craig Gagner
Craig Gagner Member ✭✭
edited September 2021 in FLEX-6000 Signature Series
Hi Flex Community,
Can a VNA or Antenna Analyzer be run through the RX ANT - A or B output. Do these ports have a direct signal path to the respective antenna when LOOPA or LOOPB is deployed?
Thanks,
w7phg
    It should work. Give it a try and make sure you don't transmit and your RF power is zero.
  • Craig Gagner
    Thanks Mike;
    I heed your advice.
    w7phg
