Flex6400M: Only gets Connection (Waterfall/Receiving) after second reboot
snet0311
Hi,
i have to restart my 6400M always one mor time after i switched on the radio, to get full access to the receiver. Waterfall is "black", Spectrum visible, but no incoming signals to see or heard.
After the Restart all is OK.
73', Stefan
73', Stefan
This would be best resolved by following up with a support ticket. They can help you out.
Hi Mike. Unfortunately it was not possible to sign in for a ticket without a registration for the „Technical Support“ first. I did‘t find any option to register. So i‘ve done some further research about the problem. It‘s solved! The powering up and down with a delay was the solution. Done so, now it‘s working. 73‘, Stefan0
Yes, you will have to register to log a ticket.
Upper right corner
Next
The Devil is in the Details. „Sign In“, „Sign Up“ first 🥲😉0
I just was receiving all red in place of my water falls on 20m and all
black on 40m?
Hi Frank, I would suggest that you export your profiles, then do a factory reset. If that doesn't help, submit a help desk ticket.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
